RE: Ignition Issues?
If you choke the engine good....fuel & oil is there. A little staring fluid is ok...but just enough to help start a engine. Also most starting sprays I have used, does say there is lube in it. OK... Once more choke ...or... prime till wet...add a tiny shot of starting spray is fine. Works on about any engine...if a little sense is used. Capt,n
