Mirage 2000
David,
Those pics are a couple of years old. I sold off my Mirage earlier this year. I am stuck on F-16`s now!! Your split elevon is a good idea, i moved the control servo (8411s`) out in the middle of the wing like you did. The inner servo is in the spot per the plans. When Eric designed this kit he was using jpx engines and the elevon setup was fine. When the higher thrust motors came along there was flutter issues with that setup.BTW i always flew mine with the centerline tank and wing pylons installed, just put the rockets on for static.
Vin...
