ORIGINAL: JCINTEXAS
I have always used glow engines, but I'm thinking of getting a DLE30. I'm sure there will be new things to learn with gas engines. My questions are: 1. What's the best 2-cycle oil to use? 2. What battery pack (voltage and type) to use for spark?
Has anyone used Klotz Modelube 2-Stroke Synthetic Oil?
Opinions and comments invited.
Regards
FASSTFLIER
here is 163 pages of info on the DLE 30
http://www.rcuniverse.com/forum/m_8885257/tm.htm
I just installed one in my ESM FW190A there really light and are a powerful alternative to larger glow engines.
there is so much hype with the oil just run some Stihl or Echo from home depot at 32-1 and your golden, there is really no need to run less oil ratio, why run a expensive Klots oil and this isn't the place to get the best opinion on gas engines best to post it in the gas forum you will get every answer in the book and probably more if you do a search
