RCU Forums - View Single Post - SYSSA 30CC GAS MADE IN USA
Old 11-15-2010 | 01:01 PM
  #3662
Mike Miller
Default RE: SYSSA 30CC GAS MADE IN USA
Hi Howard,
probably a dumb question, but here goes. My engine came with nord locks as well,,,, but. Someone must have been trying to save a buck because when I looked closer, I only had a half a nord lock under each socket head bolt. These washers require two pieces to work properly, with the "saw tooth" teeth against eash other. I have never heard of nordlocks loosening up if installed right, unless someting else in the assembly is crushing (like a gasket)
Fasteners properly torqued hold themselves in place by stretching between the heads and tapped holes. The nordlock principle simly holds that stretch of the metal in check.
Just a thought, as I have said before I certainly don't profess to know everything.
Mike
