Short Flights Troubling
Sounds like you did all the right things. Just to make sure. The clunk should not reach the back of your tank. It could get stuck to the back of the tank if it is too long.
Does your tank have foam around it? It could be foaming due to vibrations and then getting air bubbles in the line.
Good Luck. Sounds like you are good to go.
Bill
