RE: DL-50 engine mount tab broken
I have all the parts that will let you convert it to a 55cc.
You will use your old case bearings, reed, carb, stand offs, crank, prop hub, prop nut shaft and ignition.
I furnish you with new crankcase, piston, rings wriest pin bearings, cylinder gasket and cylinder.
PM me if you are Interested
