ORIGINAL: Brenner
Well, our version two Contra Drive design is finished, and Mike and Andy have all the drawings and specs. Attached are two profile views showing a Hacker C50 installation, and a Neu f3a Motor installation. I'm also showing a performance chart that shows predicted performance with various props, and gear sets.
For now the numbers are relative, because I haven't had the chance to corrolate the numbers with actual flight test data, but the relative differences should be a pretty good indicator of how performance changes with each setup. Our current thinking is that the speed is selected by choosing the appropriate prop, and then battery/power consumption is fine tuned for each setup by selecting the appropriate gear set.
Is it designed so the user can exchange gear sets or does one need another complete assembly to change gear ratios?
Jim
