ORIGINAL: Augie11
Keep in mind your engine will probably outlive your trainer by a LOT. The $$$ spent on a .46AX will go a long way and you could be still using it 15 years down the road.
This is a good way to look at it. You also might consider that many an engine on a trainer ended as a smoking hole in the ground so sometimes less is more.
