RCU Forums - View Single Post - Searching through tip&techniques
Old 11-27-2010 | 08:15 AM
MILDBILL-RCU
Default RE: Searching through tip&techniques
GOUP, In the upper, & lower corners are the pages of the thread. Some do have as mentioned, a pull down to allow jumping to other pages. Most however, do not. As you have said, the only have 1-5, or so, then some arrows. What I do is as follows; Click into thread you want, (tips & tech,) at his piont, your on pg 1, Click onto any other pg with those links at the right, top or bottom, Once you are on any other pg than pg 1, you will see that pg number in the main address bar along the top of your screen. Run your mouse over to that number & change it to the pg you want. Easy as that. Hope this helps. It has been the easiest way I have found to do what your wanting. Bill
