Searching through tip&techniques
OH
When searching through 1-10 and sign off, how can i come back and pickup on page 11 without going thru 1-10 again? Can this be done? Thanks
OH
Tom C, put in what you gave me and what came up is no Web search results. Entered address as you gave me correctly. GOUP </p>
OH
badger5964, up in the right hand corner of tips &techniques are page numbers 1-5 and i have read 1-5, but want to go to page 35 without having to go thru all pages up to 35.How can i do that? Thanks GOUP
NC
GOUP, In the upper, & lower corners are the pages of the thread. Some do have as mentioned, a pull down to allow jumping to other pages. Most however, do not. As you have said, the only have 1-5, or so, then some arrows. What I do is as follows; Click into thread you want, (tips & tech,) at his piont, your on pg 1, Click onto any other pg with those links at the right, top or bottom, Once you are on any other pg than pg 1, you will see that pg number in the main address bar along the top of your screen. Run your mouse over to that number & change it to the pg you want. Easy as that. Hope this helps. It has been the easiest way I have found to do what your wanting. Bill
OH
Thanks Bill, that's what i've been doing but was hoping to be able to just go from page 1 to page 35 or anyother pagewithoutdoing it that way, but i guess i can't. Thanks
You can just edit the page number in your web browser window.
For example, your window now shows the following web address (which only applies to the page we are seen in the whole internet):
http://www.rcuniverse.com/forum/m_10...0162348/mpage_1/key_/anchor/tm.htm#10162348
Edit the number in red and replace it with the page number you want to jump to and hit Enter.
Experiment with the thread of your choice, if it has several pages.
OH
ORIGINAL: Lnewqban
OH
<span style="font-size: larger">Tom, went and tried your method today and got it to work also. Thanks GOUP</span>
OH
MILDBILL-RCU, Thanks to you also, should have caught about the main address bar, but had a brain malfunction. Thanks everyone again. GOUP
