RCU Forums - View Single Post - Motor won't run?
Old 11-30-2010 | 04:41 PM
grimmy55
Default RE: Motor won't run?
Hi make sure you have BEC wire plugged into number 3 on your receiver it,ll still work if you plugged it into any other plug but not the motor BEC but must be into number 3 as this is throttle and as above post states make sure throttle is operating correctly ie down for no throttle up for full power
