ORIGINAL: billd76
What do think then, should I remove that washers? I love the looks of that plane and think it will be a blast to fly! Gorish go ahead BUY IT!! Come visit, bring it with you and we'll fly the wings off of them. Really can't wait to fly it!!
Here's what I did....
I did not add washers nor right thrust.
I bent the tail wheel wire out, so the plane stands more upright on the runway, and added a bit of leftward canter to the wheel so the plane rolls very slightly to the right.
I put each aileron servo on a separate channel and used flaperon mixing.
I set the flaperons to be activated on a TX switch, but I reversed the flaperon direction (not the aileron function though ).
I set the inverted "flap" amount to about 15-20%. This gives me a bit of reflex when I pop the switch. The reflex kills the ballooning tendancy.
But the best part is that I added two other mixes from elevator to flaps, also activated on a three position switch.
When I have the switch at center. I get normal operation.
With the switch down, I get elevator to flap mixing... Up elevator produces up to 80% down flaps. In this position, the plane practically loops in it's own length on a hard pull!
With the switch up, I get elevator to reflex mixing... Up elevator produces up to 80% up flaps. In this position the plane performs fantastic "elevators" in a light breeze or wind.
I also find that reflex mixing seems to help torque rolls and hovering a lot too.
