RCU Forums - View Single Post - decided on the Twist.
Old 12-02-2010 | 10:35 AM
opjose's Avatar
opjose
Default RE: decided on the Twist.
Reflex or Spoilerons... somewhat the same thing.
The "flap" button activates the spoilerons.
The three position switch gives me either the spoilerons (up) or flaperons (down) driven by the elevator, or neither (in the middle position).
I take off with normal operation... flap switch up, three way in normal position...
To perform a super tight loop, I'll flip the three way down, then return it to middle when I am done.
To perform an elevator, I'll flip the three way up, then return it to middle when done.
Just prior to landing, I'll flip the flap switch down, to activate spoilerons.
So most of the time I'm flying with the plane set up normally. The three way is used for tighter stunts... and the flap switch is used for landings with spoilerons.
