RE: Skymaster F-15 CG / control throws
Hi, Skymaster´s settings are pretty good.. mine is flown on tailerons with 50mm up/down and 25mm left/right and 25% expo. CG as manual, and it is not very critical, as I didn´t notice any drastic stability change while fine tuning it to my taste.
I also flown and helped to dial a friend´s F-15 with tailerons and aleirons.. we ended with the same taileron settings and very little aleiron deflection (we matched the side view angle of both surfaces by the eyeball method. Once this was made, the airplane got as smooth as it should be.
Enrique
