RCU Forums - View Single Post - Brison 3.2 Wanted
Old 12-05-2010 | 07:39 AM
tkg
Default RE: Brison 3.2 Wanted
There's a lot to be said for the bullet proof nature of an anvil. So many of the HP 50-60cc engines are somewhat fragile. They require rebuilds every couple of hundred hours. The typical Brison will run for much longer with minimal attention. The "weak point" on the Brison is the rod bearing 500-600 hr and the wear on the delrin ring 500-800hr. Both are simple to replace.
