ORIGINAL: 1/16 Scale Cat
So should i still use the cable way of attaching it to the servo?
That is called pull-pull control; and yes, you can use it for ailerons, elevator and/or rudder.
This i sgood reading about the available options for controling surfaces with servos:
http://www.airfieldmodels.com/inform...ware/index.htm
