RCU Forums - View Single Post - Skylark Electronics
Old 08-06-2003 | 03:57 PM
jamin
Default How many flights??
I had a simular problem with mine...3 things to check
1) antenna routing..it does not need to touch the carbon tail boom. Either wrap around a straw or go with a Deans or other base loaded antenna.
2)Tail motor....the stock tail motor is a piece of junk and does not last long..mine made about 6 hovers and then quit
3) Battery charge....are you using a peak charger or the one supplied with heli? Over charging a NiHm make it do funny things
hope something here helps
James
