Electric Indoor & Micro RC Flight Talk about this fast growing niche in rc. Micro radios, micro electric or co2 powered planes, heli's both indoors and out.
Skylark Electronics
Old 08-03-2003 | 02:16 AM
Default Skylark Electronics
Now it's an electronics issue. I think I'm going back to gas..
It will hover fine then all of a sudden it will take a notion and jerk like crazy for a second or two. Then this causes it to become out of balance and wobble out of control all the way to the ground for a rough but recoverable landing.... How the heck do you balance fix pitch / plastic blades ??
Old 08-06-2003 | 03:57 PM
Default How many flights??
I had a simular problem with mine...3 things to check
1) antenna routing..it does not need to touch the carbon tail boom. Either wrap around a straw or go with a Deans or other base loaded antenna.
2)Tail motor....the stock tail motor is a piece of junk and does not last long..mine made about 6 hovers and then quit
3) Battery charge....are you using a peak charger or the one supplied with heli? Over charging a NiHm make it do funny things
hope something here helps
James
