RCU Forums - View Single Post - DLE plug question
Old 12-09-2010 | 11:39 AM
  #111
Razor Hobbies
My Feedback: (50)
Default RE: DLE plug question
Everyone has a right to ask a question in regards to rc's.
It didn't bother me when you had asked about some sort of results or data to back up. Because im in the process of getting all my test results together my final test is just seeing if the results match up to what my telemetry says when i fly the plane. I can officially prove my test with some sort of results. I will say the Iridium plug shows a significant improvement over the basic NGK CM6.
I agree that you have to take some information you see on the internet and forums with a grain of salt. Its sometimes better to learn from trial and error. Jodi has done alot when it comes to DLE Engines so i would listen to what he has to say.
People make the mistake and judging their findings on a small test range. However when you see as many stock DLE spark plugs come back as Jodi has seen as well as many other companies including Razor Hobbies, the results are unanimous. The stock DLE plugs are crap not worth investigating. Throw them away if you receive one with the stock plugs, and buy either an NGK CM6 or an Iridium Spark Plug.
And in the most part don't beat your self up over this and that, this is a hobby and should be fun not something to argue over.
