RE: Trojan 28d question
I would start with the Cub first. The Trojan is a low wing aircraft, and the Cub is a high wing aircraft. The trojan would be a good second airplane if you have practiced alot with it on the sim, but I'd start off with the cub. Cubs are so easy to fly, its a type of sit back, relax, and just fly around. Although a first airplane should have a little dihedral in it, the cub should be just fine. I would get an instructors help or someone with flying experience for the first few flights, because it is a little different in the real world then the sim.
