RCU Forums - View Single Post - Phoenix Extra 330S 60-90 Size
Old 12-11-2010 | 09:33 AM
  #1580
BilleFly's Avatar
BilleFly
Default RE: Pheonix Extra 330S 60-90 Size
ORIGINAL: reaaz
Hii, has anyone found any composite landing gear at Graphtech RC that is a great
fit with the same scale shape as the stock aluminum one???
ADD TO WISH LIST:
***If you had a choice;is the stock one tall enough to acomidate
most props?
***Would you want it wider,or is the stock with fine?
***It would be Stronger if a slight airfoil was added;Cheaper if
it was flat.
***How much would you be willing to pay ???
I Plan to build a mold and make one for myself. The stock
one is TOOOOOO bendy and bouncy.
BUT-I don't want to take out the air-frame ethor ; with one that is too stiff !!
Tipically Carbon is Stiff but kinda brittle. Kevlar is Strong,but not stiff.
Carbon takes Sun-shine Kevlar Dosen't
SO- the proper balance of Kevlar in the middle and Carbon on the
outside is what i would look for.
The Lightest way to do that is to make a slight airfoil because,((stifness increases
by the cube of the thickness)).
So i would take an airfoil shaped mold and place ( 1 ) layer of woven carbon 5.7oz
on the outside at (+ - )45-degrees to keep it from twisting, then place
uni-tows,(or strings ) of carbon and kevlar inside with foam coar on a light plane or
nomex honneycomb on a heavy plane.
Naturaly the Nomex is REAL expensive and hard to work with.
Here is the Deal... it's a $140 ARF how much Ya willing to spend ?
Bille
