RCU Forums - View Single Post - Delro E-Motion kit
Old 12-11-2010 | 06:02 PM
  #178
MTK
Default RE: Delro E-Motion kit
ORIGINAL: d_bodary
Does anyone have any up close and personal pictures of the elevator servo mounts. I have never put elevators in a stab before. looking for good clear pictures.
Probably going to use JR 3421 servos
I just completed a "2 servos-in-stab" set-up on my latest design. I also used 3421s. It concentrates about 87 grams (3 ozs) to the tail, so make sure that your plane can tolerate that much tail weight. Turned out mine did not and I ripped the set-up out for the sake of tail lightness. The photos I have are not descriptive enough unfortunately.
What exactly do you think you need? Maybe I can describe it to you in PMs. Basically I put the servos into sockets cut into the stab. The stab was about 1" thick at it's thick section so the servos fit flush with the surface of the stab. It was a little tricky fishing the wiring back there since I don't have a plug-in stab, but I made it work
