RCU Forums - View Single Post - Fox Composites Eurofighter build thread
Old 12-12-2010 | 09:01 AM
  #32
archie2
Default RE: Fox Composites Eurofighter build thread
hi there just found your article on the fox euro fighter had a good read through me and my father inlaw built the original model that jim moulded off all was aticalled in the rc jet international mag 1 thing you might want to consider is some more powerfull servos on the elevator as we found quite a bit of push back onour first model we even considerd useing all four sections as elevators and fly it as a delta formation another thing you want to get wright is the c of g otherwise you will be in for for one hell of a ride if rearward 12mm made all the differance from our fist flight to the second one im currentley building 2 that i got from jim that will have 30 pounds of thrust if you need any infomail me any time archie also canards have loads of authority so small amount was mixed in for take off we found it helps it unstick from the tarmac as the uc are a little far back for modeling but in the scale plcae
