RCU Forums - View Single Post - Large conversion engine source?
Old 12-12-2010 | 10:16 AM
w8ye's Avatar
w8ye
My Feedback: (16)
Default RE: Large conversion engine source?
The 50cc Echo you can get a short block as the SB1080 and they are around $190. This is the biggest of the plastic frame Echo chainsaws.
The 60.3cc, 68cc, and bigger chainsaws are integral crankcase/frame engines. You cannot get a short block. You have to buy the crankcase/frame, the crank/rod assembly, and then the top end. Then you have to cut the saw frame from the crankcase.
