RCU Forums - View Single Post - Tuned Pipe throttle question
Old 12-12-2010 | 06:34 PM
_Tommy D's Avatar
_Tommy D
My Feedback: (20)
Default RE: Tuned Pipe throttle question
Yes the Kougar has a wing that resembles a park bench in it's cross section for sure! That said it's one of my favorite flyers as is anything designed by Claude McCullough. Somehow I get more personal satisfaction from making one run in the 120 MPH range then throwing up my electric Surprise 9.
Yes it's a waste of energy <like discharging one of my lipo's to storage voltage on Sundays> but I truly enjoy it.
In all honesty I think as draggy as the Kougar is, and with my RPM being what it is, Ill stick with a 10" diameter prop. Me thinks you would have to spin a 9x? awfully fast to get this brick moving.
Thanks for your help. It sounds like I am/was confusing volumetric efficiency with what I assume is the compression of the motor. I assumed at higher RPM the pipe injects more fuel/air then at a lower RPM, changing the compression and efficiency of the motor.
Tommy D
