Hi guys:
Here in Ecuador we have recived now more then 5 Wind S Pro and all have the same problem. On up line the plane will go to the cabin. CG is set like in the manual 190mm - 200mm. We can´t move any more the incidents of the elevator they are all the way up and still the plane goes to the cabin in the up line. We have try to give the motor down thrust and it fixes the problem a little but it still will go to the cabin in up lines and now the spinner is not aling and looks wierd with down thrust. The only way to make the plane fly good in a up line is to give it a Th-Ele mix on full th like a 4.5% of down elevator.
General flight very good; Snaps OK, Spins perfect, Rolls very good, Stall turns perfect; only problem is with the up lines. I bought 2 planes and both are doing the same thing in the up line.
I really don´t know what elese to do.
[:@] I´m thinking to put incident regulator to the main wing to fix this problem. [
] Has anybody else had this problem? Any ideas on why and how to fix this problem?
Hope the someone can help me with this.
Regards,
Ney
Quito-Ecuador
F3A Team
