RCU Forums - View Single Post - Wind S Pro problems
Old 12-14-2010 | 09:19 AM
namancheno
Default RE: Wind S Pro problems
Anders:
Thank you for your rersponse. So this means that there are bad kit out there in the market. That is way all of the plane here in Ecuador have the same problem with the up lines.
This really sucks [:@] [>:] If you buy a plane that does not have a main wing regulator, quality control should be sure that the wings are 100% correct.
Now to fix the problem I have to make changes to the main wings. I´m so F..... mad. I´ve waisted more then 30 flight on each plane.
It realy sucks, now fix main wings and start all over.
Regards,
Ney
Quito-Ecuador
F3A Team
