RCU Forums - View Single Post - Wind S Pro problems
Old 12-14-2010 | 09:58 AM
anders12
Default RE: Wind S Pro problems
Ney!
I think you are overreacting. The error was very minor. If you dont have a visible amount of aileron trim are your wings probably alwright. The error would not affect upplines as much as aileron trim
If your CG is at 190mm I would call it nose heavy. The manual says 200mm at windy conditions and 210mm at calm conditions. I`ve flown the entire season with the rerward CG witout problems. CG 20mm forward would give some up elevator trim giving you problem with uplines!
Regards Anders J
