RE: Permanent battery assembly
Why the two DPDT switches?????
A single DPDT with a center off position can do the same thing with less wiring???
You wire the battery to the center poles, left side to charging jack and the right side to the RX 18
In the center off positon no current flows. Move the switch to the right side and a connection is made to the RX 18 and the battery, move the switch to the left and a connection is made to the battery and the charging jack
