RCU Forums - View Single Post - Pilot RC 30cc sbach 342 build thread
Old 12-15-2010 | 08:20 AM
sawooten
Default Pilot RC 30cc sbach 342 build thread
Hello all, I haven't been able to find a build thread specifically on this plane so I figured I would start one.
I ordered mine from chief on Monday and expect it to arrive on Friday. Looking forward to building this one especially since most of the work is done already. The entire aircraft is pre-hinged from the factory.
Here's my gear I'm gonna use on it:
dle 30cc rear carb
18/8 xoar the "sword" prop
4 tower hobbies ts 150 servos (2x aileron and 2x elevator)
tower hobbies ts 150 on rudder and another small tower hobbies servo on throttle
I will be flying with a jr 7202 tx and using a jr 72 MHz rx
Servo wise it recommends a 150 oz on all surfaces and mine are running 193 @ 6 volts so should be more than enough power.
I am also using two nicad 2000 batts one at 4.8 for ignition and the other 6v
Well I will start posting pics once she arrives this weekend..... Happy flying and good luck to all
