ORIGINAL: namancheno
My planes know have a CG at 210
Do you have a measurement when the elevetors ar max out, what degrees do you have?????
Take care,
Ney
Ney,
I’m assuming you mean how much elevator throw? Well, actually I never measured it with any kind of angle tool. Rather I set it by eye (...that looks about right), then flew the plane and adjusted throws/rates from there. FWIW, I’m using the JR servo arms like in the instruction manual, but in one (1) hole closer to the centre compared to shown in the manual.
My c-of-g is pretty much on 185mm from the leading edge. The setup doesn't require any elevator mixes, i.e. no rud-elev and no thro-elev mixes. (…There is still a very slight pull to the canopy in a extremely loooooooooooooong downline, but hardly noticeable in the Figure-M, humpty with 2/4 pt down, etc..) Still have some rud-ail mixing in there.
And please post any info you have regarding your wing fences. Did you ever compare the plane without the fences versus with the fences?
Cheers,
Neil M.
