RE: need help blade cx2
The lower bearing for the inner shaft resides in a cup at the bottom of the outer shaft - right in the center of the outer shaft plastic gear. It sounds like that bearing is missing from your outer shaft. Is this a new outer shaft? New ones do not come with the inner shaft gear installed.
