RCU Forums - View Single Post - Radian - a new e-glider from Parkzone
Old 12-17-2010 | 08:14 AM
  #108
Frede2's Avatar
Frede2
Default RE: Radian - a new e-glider from Parkzone
ORIGINAL: Tom Nied
right now the motor mount is so screwed up I'm not sure what I'm going to do with it.
If you are talking about a loose motor mount -
I suggest removing the motor mount, spreading a very thin layer of Gorilla Glue on the area of the foam which is covered by the mount, misting inside the plastic, and reinstalling the mount.
Never again will you see any movement.
If you are talking about a damaged motor mount -
It should be replaced. It is fairly cheap and when a cracked mount decides to diassemble itself, the result is an epic mess.
Phil
