RE: Pilot RC 30cc sbach 342 build thread
Ok so I have run into a little issue here and of course I found out too late to call chief so now I have to wait til monday. Chief swears up and down that they check every box before it goes out to ensure every part is in it. Well my Sbach is missing the landing gear and they sent me the wrong tail wheel. So I have everything I need except the landing gear?????? Kinda a little bit important to have landing gear...... So I guess I will just continue the build and see what chief says on monday but they better be prepared for a very unhappy customer. I mean missing a control horn or something small is nothing but the landing gear???? come on guys you can do better than that.
Anyways I am gonna keep building it and hopefully I will have the gear pretty quick. So far its going really good Ive got the rudder on and servo and pull pull cables attatched and all the control horns epoxyed in. All is left is mounting the engine and installing all the rest of the servos. Should be done Sunday and I will try to get some pics uploaded. My mac doesnt seem to want to let me upload photos though for whatever reason.
The rudder was not as described, I was told by chief that it had a long pin that went through from the top and secured into the tail wheel however mine did not have this. It had 3 hinges I had to epoxy into the fuse. It was pre drilled though so that made it nice.
Will keep you all up to speed with the gear situation and the build as she continues.
