RCU Forums - View Single Post - Engine break-in in freezing cold
Old 12-19-2010 | 05:12 AM
nonstoprc's Avatar
nonstoprc
My Feedback: (90)
Default RE: Engine break-in in freezing cold
ORIGINAL: av8tor1977
Well no, it would be pretty unlikely for that to happen. If the gas freezes, it is only because it has water in it, and the engine probably wouldn't even run if it had frozen water in the carb.
What happens is that people rev the engine up and put a load on it before it has a chance to warm up. The piston grows quickly from the heat of the load, but the cylinder is still cold and contracted. This can cause cold seizures.
AV8TOR
Precisely because the engine does not run due to absence of gas/oil in the chamber, and is not break-in yet, it's cylinder head can receive excessive wear if one just spins the thing by brute force.
The tolerance between the ring and the cylinder could be smaller in freezing cold.
