RCU Forums - View Single Post - Engine break-in in freezing cold
Old 12-19-2010 | 11:01 AM
  #35
captinjohn
Default RE: Engine break-in in freezing cold
ORIGINAL: hyflyer9
The cold will be good for the engine . But some good advice do not use any spray starter fluid like you would use in a car spray starter fluid has either in it and either will dissipate the oil and may cause damage to the piston and rings .
hyflyer9
No I do not think so.
1. If you used the choke first, there will be oil in engine with fuel
2. Most modern starting sprays have lube in them
3. As soon asthe enginestarts more fuel & oil will be brought in....DAAAA THINK about it!
