RCU Forums - View Single Post - need help blade cx2
Old 12-21-2010 | 03:54 AM
AH-64_d
Default RE: need help blade cx2
Attached is a pdf file containing the CX2 parts drawing and parts list. The ridged washer is in the hardware kit, EFLH1225. Batteries eventually die with use, but store fairly well at less than full charge. If you purchased stronger motors, you will find that they perform better with a battery capable of 20C discharge rate.
File Type: pdf
