RE: Jet-Tronic Brake Valve Setup Problems
Ok. I have confirmed that the brake valve is in proportional mode. When I apply the brake, it holds for about 2 seconds and then the air is released through the brake valve. Air is release through two air outlets labeled "3". Even though this is a brake valve, it looks more like the dual-valve due to the extra ports along the bottom. Only one port is blocked via a cap.
