RCU Forums - View Single Post - Need ~45psi micro fuel pump
Old 12-23-2010 | 03:53 PM
Juker008
Default RE: Need ~45psi micro fuel pump
ORIGINAL: vertical grimmace
http://perrypumps.com/prod02.htm
Many thanks. Originally I thought that a smoke pump would do the trick, but I couldn't find pressure specs, and assumed that they would only flow at carburated pressures. If you know that these will flow 45psi or any other micro pumps, please let me know.
Thank you
