Need ~45psi micro fuel pump
Old 12-23-2010 | 02:33 AM
Default Need ~45psi micro fuel pump
Hello 'all,
I didn't know where exactly to ask this questions, so I figured I would post it here. I am looking for a micro high pressure fuel pump. It doesn't have to be high flow, but needs to be high pressure. Size and weight are a big concern.
MTIA,
Old 12-23-2010 | 08:51 AM
Default RE: Need ~45psi micro fuel pump
Since the jet forum already has discussions about what you need I'll suggest looking there.
Old 12-23-2010 | 09:03 AM
vertical grimmace's Avatar
http://perrypumps.com/prod02.htm
Old 12-23-2010 | 03:48 PM
ORIGINAL: Tired Old Man
Well this isn't a jet project that I am working on, so I didn't know to look there, but I'll give it a gander.
Old 12-23-2010 | 03:53 PM
ORIGINAL: vertical grimmace
Many thanks. Originally I thought that a smoke pump would do the trick, but I couldn't find pressure specs, and assumed that they would only flow at carburated pressures. If you know that these will flow 45psi or any other micro pumps, please let me know.
Thank you
