YS 140L pushrod lengths
Hi Dave,
Thanks for your response.
Shorter by about 2mm (approximately 3/32”). It may not sound like much but it’s obvious they are of different lengths. Also FWIW the shorter one is not bent as I checked for straightness by rolling on a bench top.
Would you expect the pushrods to be the same length? Moreover, and in your experience, how much variability, if any at all, do you see in pushrod lengths, from the same engine and/or from engine to engine?
Thanks.
Cheers,
Neil M.
