RCU Forums - View Single Post - Support for Regulations By The FAA
Old 12-24-2010 | 03:00 PM
  #113
KidEpoxy's Avatar
KidEpoxy
Default RE: Support for Regulations By The FAA
Hook
2. I already do. As long as it is done in accordance with AMAs document #550
That is completely not answering the question asked-
Hook, regardless of how you feel about AMA 550pdf,
Would you give 'Support for Regulations By The FAA' requiring non-LOS recreational model craft to have Pan&Tilt camera
so they CAN look around to use Find&Flee?
(exactly like VFR flights in a c172 look around)
Either you would support the FAA saying a single non-LOS pilot will require Pan&Tilt (aka T&E for mil folks),
or you wouldnt.
If you wouldnt support the Pan&Tilt FPV pilot having the same views that a guy sitting in a c172 has,
explain why that is not acceptable to you
