Go Back  RCU Forums > RC Airplanes > AMA Discussions
 Support for Regulations By The FAA >
AMA Discussions Discuss AMA policies, decisions & any other AMA related topics here.
Old 12-28-2010 | 07:44 AM
  #176
Default RE: Support for Regulations By The FAA
IMAC is a SIG of the AMA.
Old 12-28-2010 | 08:56 AM
  #177
If 400' @100mph becomes the hard and fast standard it will kill any competition in this country and abroad. But hey, America isn't competitive at anything anymore other coming up with new and inane rules to regulate everything for our safety and security. The Japanese whom we dropped bombs on in WWII kcik our butts at everything, education, technology, education even baseball. What's one more thing that most Americans will never really miss? We just play with toy airplanes anyway. Isn't that right?
Old 12-28-2010 | 09:42 AM
  #178
Silent-AV8R's Avatar
As far as competitive on the world stage in RC I think it is worth noting that this past summer the US Junior Team won the F3J (thermal soaring) World Championships. Brendon Beardsley is the current World F3J Champion and Daryl Perkins won the senior World Champion title. Daryl is well known in soaring circles having won the F3B soaring championships FOUR times.
The US has done fairly well over the years on the world stage at various FAI events.
Old 12-28-2010 | 10:07 AM
  #179
KidEpoxy's Avatar
PilotFighter
Houston is a very large city. Houston has about 15 clubs in the area. Houston also has nearly 50 commercial, corperate, and private airfields. Finding a place to fly models that is more than 3 miles away from an airport is difficult. For that reason, many of the Houston area clubs are within 3 miles of an airport. And most Houston flyers are aware of the 400 foot rules.
are you familiar with the Zero Ft Rule near airports?
Compare the now (ac91-57) with the could be (sUAS ARC):
c. Do not fly model aircraft higher than 400 feet above the surface. When flying aircraft
within 3 miles of an airport, notify the airport operator, or when an air traffic facility is located at
the airport, notify the control tower, or flight service station.
3.3(4) Model Aircraft shall not be operated within 3 NM miles of an airport, heliport, or
seaplane base without the permission of the ATC authority or airport manager.
Consider the chat needed with the airport when within 3miles:
Mr Airport, we are flying above 400' saturday and are notifying you as AC91-57 reccomends,
other than Saturday we will be below 400 so we never even call you
vs
Mr Aiport, may we please fly at all on saturday,:
We humbly beg for sUAS 3.3(4) permission to get off the ground with a model near your airport
Old 12-28-2010 | 11:52 AM
  #180
TexasAirBoss's Avatar
My Feedback: (22)
ORIGINAL: KidEpoxy
PilotFighter
vs
Any past signatures aquired proving that the airport operator was notified of model operation within 3 miles would probably constitute permission of same unless the operator stated otherwise. Either way, it is only a pow wow and a signature. However, in light of the post above summarizing the jist of the meeting thus far, it appears the FAA has backed away from regulating MA directly. It is unlikely that this restriction will see the light of day. The AMA would need to voluntarily write such a rule. Or be coerced into writing such a rule by threat of regulation from the FAA. But the FAA has already admitted they intend to avoid the legal and finacial can of worms of regulating MA. So, why would the AMA write such a restriction? I believe the worse case that we will see come from the current confrontation is that the AMA might take out the comma and return the saftey code to the agreed form of 1981. It sounds as if the comma is the FAA's main point of contention. I just hope that our boys have the brass to stare them down.
