lipo in a dx7
ok time to open a can of worms i noticed my tx stock battery is charging less and less mah every time im going to convert to a lipo 3s 11.1v but here is my conserns will it work fine if i just install the battery in my trans the read out will be 12.6 volts full charge. or shopuld i add 1 recetfying diode in and drop it .6 volts or add 2 and drop it 1.20 volts? if anyone is useing a conversion on a dx7 please let me know i read the reglulater in the tx has no heatsink ( opened it up to comfurm and sure enough it does not) im just wondering beings there is a low volt draw if i should add the dioes or not and i dont really feel like messing with the volt regulator in side the tx as some sight s give this as a quick fix i need help this is driving me nuts on what way to go
