RCU Forums - View Single Post - 85" Cap
Thread: 85" Cap
Old 12-25-2010 | 07:01 PM
  #43
cap10b's Avatar
cap10b
Default RE: 85
All,
I'm sure this thread is dead but I just recently acquired an 85" Cap 232 and I too encountered the above triming issues. I purposely installed a known heavy powerful motor to A - test this motor and B- to have a good throw down plane for weekend hacking around.
I think Tom is correct you do need to plan and work a little harder to get the plane trimed like you want. I see no problems to get the plane to do what I need to do.
3W-60K swings a 24x8 TF prop at 6500 or 24x10 Bunny @ 6000
Bisson DA50 Side mount muffler - test at our field 96DB at 20 feet
RCXEL single ignition replace the old 3W ignition, set at 28 degree BTDC.
Dual A123 2400 MAH batteries
2ea 94851 New Airtronics sport digitals on elevators
2ea 94162z analogs on ailerons
2ea 94162z on rudder
Hitech 225 MG on throttle
Radio Airtronics Stylus 2.4 module on FHSS1 8 channel 92824 2.4Ghz receiver.
This ship weighs 18 lbs solid and I have no added weight to balance
I am at the 4" CG mark at the wing tip per instructions.
JDS
ID:	1538274   Click image for larger version
ID:	1538275   Click image for larger version
ID:	1538276   Click image for larger version
ID:	1538277   Click image for larger version
ID:	1538278   Click image for larger version
ID:	1538279   Click image for larger version
ID:	1538280   Click image for larger version
