Ignore the blurb at the top, looks like it copied the header from Word.
Hey YHR couple of simplistic questions for you. Being a mechanical minded person my electronics experience is limited to playing with computers. So I am kinda lost on this whole thing.
<meta content="text/html; charset=utf-8" http-equiv="Content-Type"><meta content="Word.Document" name="ProgId"><meta content="Microsoft Word 12" name="Generator"><meta content="Microsoft Word 12" name="Originator">
So question time!
- I take it you are piggy back onto the standard Heng Long speaker and volume control, or are you using the speaker supplied?
- I am presuming all a voltage regulator does is...well regulate voltage, in this case reducing it to what the card can handle?
- Would it be possible to wire the 123 sound cards power supply to the motors power. Essentially I would be looking for the sound to play when the tank moves and I was thinking perhaps of wiring it into these wires.
- I take it the sound card could not be set to play a proportional sound, i.e slow it down when moving slowly, pick it up when moving quickly?
And a final barrage!
Last but least, Iam looking to wire it into a particular type of RX18, not the one with diesel chatter or clanking tracks. Typically this type has a low sound output, would wiring this card affect that?Does it have its own pre-amp or could I fit an amp in-between the RX18 and speakers. If so any recommendations from your experiences and what is the max limit on the stock speaker?
Thank you!
</meta></meta></meta></meta>
