RE: mvvs 58 limited edition
Hi Pe, thanks for the quick reply
Prop still the Xoar 24x10 (wood).
M5 bolts are not bottomed out though now i know the torque setting they will always be torqued.
Central bolt is more tight than snug, the only time i did it snug was when the nut came off in flight, heared it rattling around in the carbon spinner and land straight away.
Do you think i should take the hub off to check all is ok as i can clearly see part of the wooddruff key, though the gap between hub and crankcase is still the same, if so could you tell me the best way of getting the hub off.
I will check all igntion and battery connections and wires for damage/loose.
Steve
