RCU Forums - View Single Post - Support for Regulations By The FAA
Old 12-28-2010 | 11:52 AM
  #180
TexasAirBoss's Avatar
TexasAirBoss
My Feedback: (22)
Default RE: Support for Regulations By The FAA
ORIGINAL: KidEpoxy
PilotFighter
Houston is a very large city. Houston has about 15 clubs in the area. Houston also has nearly 50 commercial, corperate, and private airfields. Finding a place to fly models that is more than 3 miles away from an airport is difficult. For that reason, many of the Houston area clubs are within 3 miles of an airport. And most Houston flyers are aware of the 400 foot rules.
are you familiar with the Zero Ft Rule near airports?
Compare the now (ac91-57) with the could be (sUAS ARC):
c. Do not fly model aircraft higher than 400 feet above the surface. When flying aircraft
within 3 miles of an airport, notify the airport operator, or when an air traffic facility is located at
the airport, notify the control tower, or flight service station.
3.3(4) Model Aircraft shall not be operated within 3 NM miles of an airport, heliport, or
seaplane base without the permission of the ATC authority or airport manager.
Consider the chat needed with the airport when within 3miles:
Mr Airport, we are flying above 400' saturday and are notifying you as AC91-57 reccomends,
other than Saturday we will be below 400 so we never even call you
vs
Mr Aiport, may we please fly at all on saturday,:
We humbly beg for sUAS 3.3(4) permission to get off the ground with a model near your airport
Any past signatures aquired proving that the airport operator was notified of model operation within 3 miles would probably constitute permission of same unless the operator stated otherwise. Either way, it is only a pow wow and a signature. However, in light of the post above summarizing the jist of the meeting thus far, it appears the FAA has backed away from regulating MA directly. It is unlikely that this restriction will see the light of day. The AMA would need to voluntarily write such a rule. Or be coerced into writing such a rule by threat of regulation from the FAA. But the FAA has already admitted they intend to avoid the legal and finacial can of worms of regulating MA. So, why would the AMA write such a restriction? I believe the worse case that we will see come from the current confrontation is that the AMA might take out the comma and return the saftey code to the agreed form of 1981. It sounds as if the comma is the FAA's main point of contention. I just hope that our boys have the brass to stare them down.
