red 4*60 orientation issues
Sorry .... but ultracote is the "whole heat iron/gun" thing. It's what your plane is currently covered in right now (except it's branded as Oracover because it was imported from ger to china)
There are pro's ad cons, I think it's easier to remove than the stick and peel with some heat, so if it's not good enough you can make changes (I've done the 2x already to increase visability). Lot's of pro's here who can help with your ultracote questions. I'd be curious what you finally come up with. Mike
