RE: mvvs 58 limited edition
Two more options:
Is the ignition kept cool? If the ignition works well on cold engine, it also should work well when the engine heats up.
Is your engine cooled well? Pictures please.
Lean the top end (H) needle to best rpm. Then turn the screw a hair (1/16 th turn) counterclockwise. This must be done with hot engine.
